1 - 9 of 9 Posts
93 Legend L Coupe.
Yes. It is not for long-term driving, though. For intial startups, this is generally better as there is less chance of the detergent stuff stripping away your cam and bearing lubes too quickly, or possibly foaming. It should also be cheap, since you are only going to get a few heat cycles out of it, if that, before you drain it and use something else.
I used a similar oil for mine. I had maybe only 15 miles on it before I changed it out. I got a brand 'accel' at walpoop. Also was a little skeptical about it saying not for 'modern' vehicles. But after researching, it seemed good becuase like ^^ said, its not in there for very long. Make sure you prime the oil pump before you actually fire it up!
97 honda coupe
how exactly do you do that on a honda?
I ran my build on this stuff for a couple miles and then changed it. I heard rushi cuts his with ATF fluid to get a really shitty oil.
96 ex coupe
pull plugs & pull fuel pump fuse out, and do like 5 second hits on the starter with 5-10 second breaks in-between so u dont burn up the starter. check you oil pressure gauge, once you start building pressure you should be good to go. Also once oil hits everything internally, you'll hear everything spin much easier & faster.
1 - 9 of 9 Posts
