1 - 14 of 14 Posts
Ok, might have made a mistake getting these 10mm Hotwires, mainly because i have no idea where i can rig the ground wires for each one, main issue is the length of the groundwires, they wont reach very far from where they are, anyone have any suggestions, if pics are needed they can be provided.
91 crx HF/67 jeepcj5
iv used them before and got a differance.
i put my grounds on the valve cover studs
they stop fouling if it run a little rich
jesus...ok screw the hotwires lol...so is it advisable at all to do upgraded wires? Someone mentioned NGK wires, and im thinkin maybe going to 8.5mm or something.
lol, well that settles it, im using NGK Iriduim plugs, so i might as well use NGK wires with em.
CR-Vtakin
your mom
ngk wires are awesome, msd is another great option. nology wires are horrible. i had a set on my accord and they caused problems, caused nothing but problems on my friends civic. basically, total garbage.
NGK Coppers and new OEM wires FTW! Thats probably the best and most reliable spark I will get without some serious ignition components, which I don't need.
1 - 14 of 14 Posts
