1 - 1 of 1 Posts
Hello. i puta single-zc,(going from a B8)and was so excited..was running a pm6, then put in a pg7 and went for a fun run....not soon after the engine started producing a odd noise.at first thought it was a loose bracket.then thought valve/rocker ajustment..those looked fine. so anyways i checked everything. i wouldnt be writing,wasting other peoples time.but im asking for help.i got the head off, checked the valves from bottom veiw. all looks good.(not one spring shorter than other)(i also took off the rocker assembly) heres another thing.with timming belt off, (engine assembled)spinning the cam gear with 12mm ratchet,was hard.. sooo i assumed head probs...so maybe with the higher revving pg7, some weak spots came out..... You guys have helped sooo much, with responces and just reading posts.(in the past)i thank u and hope for more help. i may be stepping away from pc so ,ill ga=et back with you all later. what im asking is what generaly goes.. rod bearings..or what??i puzzled
1 - 1 of 1 Posts
