G
·hey, i have an 89 crx si i just replaced the clutch, pilot bearing, and throw out bearing since then it has started making a grinding noise when decelerating with the clutch engaged as soon as you depress the clutch pedal it stops it gets worse when i turn corners without applying the gas, please help thanks...
