1 - 12 of 12 Posts
went to adjust tps, noticed its been messed with before. bolts weren't snug. so, took throttle body off, cleaned it, checked tps, put it back together, and tested for voltage. I have 5v from white and green. when plugged in to tps and measuring off red/blue and green, nothing. adjust tps and still no voltage. cooked ecu? broken tps?
Bad TPS, I had the exact same thing happen about a year ago, I got one of the $8 specials off ebay or amazon and put on, tested the sweep, and adjusted it, it has been fine ever sense.
lol, cant exactly do the ebay route since I needs me car lol. well, actually, I could bolt it all back up and run it as is right? Im thinking of hitting the junkyard tomorrow and pocketing a few...
I don't have 43$, but I do have 2$ and a few hrs to kill, so Im heading to the junkyard to grab 2.
The other possibility is that your sensor wire is grounded somewhere, but I think bad TPS is far more likely.
I got lucky and found a civic with a new tps sensor and allen head bolts. no gaskets though, so hopefully I can reuse mine, or rtv it. also got a throttle stop screw. wont be able to do anything about it today, got to run around until 6. hopefully tomorrow I can button it all up
first try, tps was adjusted correctly. code for that is gone. replaced the iat, cleared the codes, and the damn iat code is back.
Check iat wiring might be a broken wire. Look close to the plug where the seal is.
lets hope its something simple. the old one was melted, wonder if it may have shorted internally?
also, still smelling fuel, wonder if it could be the injectors
1 - 12 of 12 Posts
