1 - 14 of 14 Posts
i just got done with my mini and i have NO spark. the timing is perfect, the distributor is BRAND NEW...WTFFFFFF...one thing tho, my buddy said that when i was checking my firing order and i had my distributor cap off, that little coil spring fell out....will that cause this??
Use the helms. Check for ecu codes.
haha the thing is i had a haynes manual and its gave the totaly WRONG fring order for my car so i had to look it up.
98 Civic EX
98 Civic EX
Yes, you might also check the "ground" wire that attaches to the thermostat housing. If it isn't hooked up it won't fire and the fuel pump won't come on.
okay so i got a new spring, and i still get the same thing...its turns over but i get nothing but backfire. the grounds is connected....so i have no idea. any new ideas??
HAHAHAHA she purrs like a kitten....well not really. turns out mitchel ondemand is wrong to. i looked in and old chilton book of mine and got the firing order. thanks a ton for all the help and suggestions!
1 - 14 of 14 Posts
