1 - 11 of 11 Posts
2000 Ek sedan
So the other day I was working on my car replacing a thermostat and my vtec pressure sensor, when I went to start my car it ran perfectly fine but then after ten mins or so idling the idle started to bounce. I started to pull some spark plug wires to see if that would change the idle or anything and when I pulled the third plug the car shut off. I tested for fuel, air, and spark and im getting everything but spark. I checked wires, plugs, cap, rotor, ignition coil and everything is fine any other ideas?
bleed the air in the coolant, clean and tighten the thermostat ground.
2000 Ek sedan
1 - 11 of 11 Posts
