:ninja:3rd gen Dohc ZC. Obd1 with Chipped p28 ecu with respective basemap.
I already checked for signal at the ecu. I've used an ohm meter and test light on power source to dizzy. Changed cap and rotor. While it was off, I checked for power at the shaft, and nothing. I took ohm tester to every fuse under the hood. checked the alternator fuse, which I heard sometimes keeps dizzy from sparking? Have not checked main relay yet, or ignition switch. More diagnosing tonight.
Anybody know anything about this? I've already tried switching the white wires on the dizzy plug. I've already checked mechanical timing.
ZERO SPARK
ZERO SPARK
