1 - 19 of 19 Posts
what a good birthday present! haha
So i took the plugs out to check the compression... checked it, 165 -170 okay fine, put the plugs back in and now no spark? Nothing looks broken on the distributor and ran perfectly before the compression test. Any help?
If you haven't read my other threads.... D16y8 with y7 internals and 120 miles on motor now. Thank You!
*The distributor IS getting power*
98 Civic EX
any CELs?
posibly icm?
could be an unplugged wire, or possibly the fuse you removed for the compression test...if you didn't remove the fuse check the box for a blown one
1992 Civic VX Stock
This happened to me with my VX. The coil went bad. Seems odd but when you think about it - it makes sense. The high voltage had nowhere to go so it arced inside the coil - destroying the enamel insulation on the wire.
98 Civic EX
or at least remove the ignition fuse
Adia's Daddy
2004 Honda Element
Also known as letting your ignition system "run wild".
Your typical good Honda coil output is around the 30-45kV mark and that amount of electrical pressure can do magical things when it's allowed to go where it may.
P.S. It's quite an experience to have it go through you via an appendage too close to an arc point :pinch:
98 Civic EX
o god, this happen to me while i was testing the spark on an escort for a friend...now i know what it feels like to be tazed..hahaha
Adia's Daddy
2004 Honda Element
I had an ignition system on a running 2001 Accord arc to my finger one time through a cracked distributor housing. Good times :wacko:
If you want some REAL fun, old style timing light, not the new stlke induction clamp on.
Catch someone with their bare stomach laying on the fender and disconnect the ground wire for the timing light from the battery.
It'll knock your dick stiff!
98 Civic EX
ROTFLMAO!! thanks trans
speaking of which my wife knocked my dick stiff this morning and then fixed it for a wake up call...:D
Adia's Daddy
2004 Honda Element
*jealous rearing it's ugly head*
Fuck you have no idea how many morning boners have been completely wasted on my end here in the land of singledom :pinch:.
civic
ive actually exsperianced that shit.. its not fun
98 Civic EX
that's sucks man, sorry to hear that...
Adia's Daddy
2004 Honda Element
Haha no worries man. I have a very nice and very pretty friend with benefits who visits so I don't go completely without :bigok:.
98 Civic EX
ain't notin wrong wit dat
Defender of the D
try being just the right height and it arcing through the zipper on ur jeans.... OOOOHHHH SSHHIIIITTT no a good feeling.
1 - 19 of 19 Posts
