1 - 20 of 50 Posts
I've tried searching and can't come up with any answers. After the mpfi swap in my 91 Dx the car will start and run for about 3 sec and then shut off. If I hold the throttle open it will stay running. I have checked the tps and its at .50 at idle and 4.5 wot. All the grounds are good. What else would cause this?
Thanks,
Mike
could be a couple of things could be a faulty ecu
a wire in the wrong place
could be something haveing to do with the injectors and ecu wiring
but beyond that im not to positive on it since ive never done this wanted to but have never attempted to
The car would start and stay running after the swap but the tps was bad and the car was a little out of time and ran really rich. (it's a d16 head and cam on a d15 block). Now I have an adjustable cam gear and have got the timing squared away. I replaced the tps and distributor with known good ones. The real question is why would the car continue to run before swapping the tps and distributor? I thought of the ignition module and tried my other distributor, but it had the same prob. Starts and idles, but dies after a few seconds. Or will start and run as long as I hold the throttle part way open.
Sorry for the broken sentences and thoughts, just running out of ideas.
Thanks,
Mike
No the cables fine. It doesn't seem to be mechanical. It will run great unless you let it idle for a few sec's then it dies. Again it didn't do this before the new tps, (which shows to have good voltage at idle and wot).
Sounds kinda like the ECU to me. Have you tried putting in a known good on e and going from there? Similar to my issue which was the ECU. Also issue may be a dirty IACV? you might try that since it free and easy to do also
Goodluck with it
Well I could try to find another pm6 locally that I could borrow. Since it would idle before when it was out of time, would it likely be a Iacv? I will try anway's since I'm sure it needs to be cleaned. Any other Ideas?
well being idle related issue, I would think it one of two things other than the ECU. The first things I would check would be the IACV and the FITV. they both are idle controllers. Check and clean them and go from there.
That I dont know man. You could try switching them and see what happens. I dont think it would hurt anything
whatever runs....
probably a map related code, maybe a lean condition or rich condition,and a tps code....? the plugs are the same, but the wires are different colors, check your service manual wire charts to see, or just swap em real quick and see what happens....
No fitv on this manifold, or at least if there is it's not where i've seen others. It's located on the rear of the manifold toward the drivers side correct? If so there isn't one. I will try the Iacv tomorrow, I can only hope it's that simple. I have had this car down for 3 weeks now waiting on various parts and gas mileage in my truck is starting to kill me.
Before the new tps it would throw tps,map and cps codes all at various times. I have replaced and adjusted everything to where it's not throwing any codes now.
Discussion Starter #19
No the coolant lines on the bottom of the tb are not hooked up. I was under the impression you could block them off and not use them. (oops) This is true on turbo buicks and I thought I read it on hondas too.
1 - 20 of 50 Posts
