1 - 3 of 3 Posts
Now the car won't turn over I thought low fuel so added a few gallons n nothing its turning over n the fuel pump relay is clicking over any ideas y'all?
fuel getting to the injectors?
spark at the plugs?
timing correct?
OK wierdest shit but umm so I pulled my starter signal fuse an turned over an it FIRED right up but i put the fuse in n turned off an still fired right back up. Still no power to acc cig or radio? Ac has power same with heater. No clue went an changed to new fuses anyways. No change. Same with under hood box new fuses
Yes I changed all the mini ones to new ones still no power to ratio or cig
1 - 3 of 3 Posts
