i purchased a speed factory no notch H beams vitari pistons and i was wondering if any knows if that the piston rings come pre gaped we put them in as is thinking that they are already gaped i have a d16y8 and its bored out .5 over
pretty sure you're gonna need to gap the rings, or at a minimum verify that they are correctly gapped. I think good practice would be to check ring gap no matter what the seller said if it doesn't come pre-assembled.
93 Civic HB SI
Never assume rings are gapped. Usually they are not, and if they are they will most likely have a gap for NA duty, which would be too tight for turbo.
Always put them in the cylinder and check with a feeler gauge.
My last 75.5mm vitara experience did not have rings gapped for turbo, I had to cut them quite a bit wider.
Sloppy Jalopy
well put them back out ...
you need to make sure of the gap with a feeler on every build .
.I have never seen a pre gapped ring out of the box..especially not turbo d16 spec ,,
