1 - 7 of 7 Posts
Ok so i took a trip in the sol and about half way there, something happened and it started skipping, but i don't think it was.. So i turned it off, and then turned it back on about 6 hours later, and no music plays out of the speakers! By subs are hitting but no music! I think it might be the CD Player, i'm going to take it back, cause it don't fit in the car good anyway.. Anyone got any input? Help appriciated!
Any help? :(
Lol ok, i'll try that before i take it back..
check your speaker wires. they might be touching and grounding out.
werd make sure the terminals are not touching the bare metal especially on the front speakers that are mount in the door ;)
FAMILY MEMBER #316
do you have a four channel amp? did you install it or was it done by a professional? did you install speakers at the same time? more info...
unless you got a turd for a radio (dual, jensen, etc...) it is highly unlikely that the radio itself is defective. that type of failure will usually occur way down the road in the life of a cd player.
1 - 7 of 7 Posts
