1 - 11 of 11 Posts
After porting my IM, I found that my knock sensor(being plastic) had broken
Now I'm running with my CEL on 24/7. The car runs great but I know this is a problem. Is there any resistors or dummy sensors out there for cheap that I can suppliment in for the KS?
I had that same problem. I drove it for a while with the CEL on but then I found out that if you go to radioshack you can buy a piezo buzzer (It was a 3-20V I think). splice into the wire going to the KS with the red one and just ground the black one and tadda no more CEL.
I have read on ht that you can ground out the knock sensor cable
L
Honda wouldn't spend the money for the extra shielded KS if it wasn't needed, its retarding your timing to protect the motor from detonation. Don't bypass it, replace it.
1 - 11 of 11 Posts
