1996 Civic Type DX
SRR countershaft
Z6 2nd gear
one synchro spring was bent so I replaced it, other than that, everything appears to be fine and correctly assembled (3 times).
Reverse gear/synchro will not engage 1st or 2nd gear, it is stuck in place with very little play.
Shoot away with your suggestions. I need all the help I can get.
Have to have my car running by Monday night. 800 mile trip on Tuesday starting in the early AM.
1996 Civic Type DX
Fixed it.
Goes in all gears, but when clutch is disengaged in second, all it does is grind. Third has started grinding on shifts now.
These were not problems beforehand. Reused stock synchros.
