1 - 2 of 2 Posts
Z
if someone has a single wet kit...what exactly is needed to convert it to a direct port system ? also is a stock z6/y8/a6....ableto handle an 85 shit direct port or is it to much for the little d-series .......im talking stock internals of course....
Curious George
hell fucking no.
Run under 65shot on stock internal with fine tuning is more than enough, more than those number is playing with fire.
If you want run direct port you need newer system if you don't want to mess everying up. Direct port is used to handle more nitrous shot, and safer by dividing equal nitrous shot to each cylinder.
If you don't plan to build your engine and make it tuned by proffesional, don't do it.
Knowledge before prevent mess.
good luck
1 - 2 of 2 Posts
