1 - 11 of 11 Posts
D-series child
So last night at the track I noticed my bottle pressure gauge wasnt reading, yet the nitrous was working... very well.. :lol: There's no clogs or anything in the way of the hole. What can be causing it? Did I get a bad one?
Also, When disconnecting the nitrous line I found that air was coming from the hole beneath the gauge. Do I need to plug this up or is this gauge a lemon? I didnt drill nor make that hole. Pic below.
i have alot of fittings like that it shouldnt have anything comming out of it you might need to tighten it up a little better. but it sounds like you have a lemon. the gauge would read some thing even if it was letting some out though that hole
D-series child
shitty install.
what are you talking about?
Yeah, Im not sure. I put teflon paste around the gauge, so Im sure its not leaking, but while disconnecting the line air was hissing out of that hole. Should I take it back and get a new one or what?
well if there is pressure and the gauge is showing 0, then yes take it back.
IIRC, those little holes are for safety wiring.
Once you broke loose the conection, the little holes were easiet exit.
1 - 11 of 11 Posts
