I want to add a nitrous filter to my setup before I run it but I am confused about how to hook it up in-line. It has a -4AN fitting on both sides so the only way I can think of would be to add another short hose so it would go:
bottle > 2ft -4AN hose > nitrous filter > 15ft hose > nitrous management unit. Is there a better way to do this? I really don't want to add another hose if I don't have to and I can't seem find much info on these filters. :TD:
Also, I am getting a fuel pressure safety switch and I need to know what psi I should set it to? I am running a ZEX Dry kit. I was thinking something like 45-50psi?
fuel pressure safety switch not needed with ZEX.
Mount the filter right to the bottle......I think I used a 90 4AN......let me find the part numbers I used.
Thank you very much, I'd rep you but I need to spread it around first. lol
that filter is serviceable, you'd be surprised at the junk it catches.
Better to spend extra $30 on the filter than have to keep replacing solenoids or clog a jet.
