New years for sale
1174 Views 24 Replies 11 Participants Last post by  str8venom99
No Longer...New years for sale
FOR SALE
AEM tru time ZC cam gear(brand new) $50
D16Y8 Intake manifold (auto) with fuel rail,pressure reg,and injectors $60
Civic pedal set (auto) $10
D16Y8 throttle body (auto) $20
D16 starter (auto) $25
Civic D16 axles $25
98 civic ex AUTO transmission $150
Casper's H4 HID sheilds $20
Stock eg shift stick $10
Stock springs 98 civic ex coupe $25
Integra gauge cluster bezel $10
BMW E46 bi-xenon projectors for hid retrofit SOLD
Battery box $10
self brake bleeding kit - $40
3 way 4x6 speakers $20
96-98 civic front bumper front opening cut out $20
7th Gen civic OEM cd player $50
P2P auto ecu
1 - 20 of 25 Posts
bump for looking
want the projectors!
pm your paypal.
wish i had the money bump!
Is there something you plug to make an Auto TB and Manifold work on a Manual? Do you have the FITV and IACV to go with that TB + Manifold?
Actually I suppose there wouldn't be... why else would you be selling them?
the auto y8 manifold iacv ports are blocked off. the auto y8 throttle body has the fitv and iacv attached to it. i have seen where you can drill the ports out for 5 speed manifold iacv. or swap out a y7 im for the better flowing y8 and keep the y7 tb without converting to the 2 wire iacv system. I'm sure there are other applications that can be used wit this(anyone else that knows can chime in at anytime)
these are parts ive takin off my own car possibly someone might need these that why im seeling them
bump for good jdm stuff..:wink:
the auto y8 IM is better for a manual y7...u can even keep your y7 tb but would have to swap the rotor out so therefore, you would probably want the y8 auto TB...but if u ever decided to do a mini-me or swap a y8 into ur y7, you'll need the manual y8 IM withe the 2 wire iacv on the back of it, and a manual TB bc the hole for the 3 wire iacv in the y7 and auto y8 TB will cause a massive vac leak unless blocked
1 - 20 of 25 Posts
