1 - 11 of 11 Posts
C
Hi I just got a 1989 CRX and the guy has put a d15z1 motor in it. He said this motor is a sohc vtec motor but the ecu is the factory one. So my question is will the vtec work with a factory CRX computer or not? If not is it worth making it work and what would I have to do to make it work?
Ferio inspired
90' Civic sedan
it can if you use a MSD rpm activated switch. but it's so much better to convert to OBD1 and run a p28:beer:
The H Badge is it!
91 crx
your d15z1 motor is a vtec-e motor.
to make it run 100% correctly you'd have to convert to obd1 and use the civic vx ecu
id swap the motors if i was you.. makes things easier
L
oh yeah by the way the z1 motor is trash. strong motor but just didnt do it for me. but i heard if you run a p28 or p08 the wtec-e's run a little better.
sub-sponsor
93 civic
if i were you id sell that motor swap in a jdm sohc zc or dohc zc
C
Thanks for your help I'll probably drive it the way it is for now because it's the only daily driver I have and save up for an engine swap.
^^I would definately do different engine swap if you are going for speed not MPG :) Save up for a Z6 or ZC.
VX ecu is the p07...
uses a wideband o2 sensor stock... (5-wires)
1 - 11 of 11 Posts
