1 - 20 of 20 Posts
im new to honda im a jdm guy who bought a sohc d16zc vtec im trying to find out some info on the motor i have googled part numbers all i can come up with is the piston numbers(p07) so far there from a d15z1, but i cant find anyother info on the head(p08-6) or rods(m.3:6). can anyone help me out it also dosent have a vtec like the rest of the d16s with the popers on top. here are the pics of everything. thanks for any help
It looks kinda sloppy, like someone ground the block stamp, and tried to re-stamp it. That's suspicious...
ministry of mayhem!
93 honda integra
idk if your stamp is legit or not, but according to a search on the intrawebz:
ok
well it ran fine before i pulled it out n put a new head gasket on it. it mite be jdm. but idk.. i just wanted to kno about the head more. im trying to find out if it was assembled with random d parts.
Right, but that valvetrain doesn't look like a d16z6 at all, nor a d15b. No LMAs. Also, look closely and it looks like roller rockers.
I'm guessing it's VTEC-E, that is, a D15Z1. On the block stamp, you'll notice that only the "6" and the "C" look shitty. Thus, "D15Z1" modified to "D16ZC"
Whoever modified that stamp was a total jackass.
well thanks can ne tell me a lil more about e-vtec
how do i figure out what block it is i kinda need to kno because i bought a d16z6 water pump and timing belt the water pump bolted right. and i timed it like a d16z6. the belt has the same number of teeth. it spins free and easy
Its not a d15z1 then cause they use a different water pump then the z6 you might have got a b7 with z1 head and pistons. Someone threw that thing together cause you got a freak motor lol. And my jdm d15b
itakes the z1 water pump. Its different from the other 2 or 3 motors that came in the 92 to 95s.
What's the code on the ecm/ecu?
That might help a little more figuring out exactly what you've got there.
stupid block
the cpu is p28 it was running when i took it out. everytime i get a motor i put a new water pump, timeing belt, and head gasket/head bolts. thanks for the help guys
You're wrong. Water pump off the D16Z6 is the same Honda P/N as the D15Z1. Both use 19200-P08-004. He has a D15Z1 block.
@mr.todd you are correct I did get them confused the b7 is the water pump that fits on my d15b. So yes most likely a z1 block. And the head casting is a z6 casting number. So you got a vtec-e bottom and z6 head is what it seems to be.
1 - 20 of 20 Posts
