I got a 60mm throttle body off an H22, but the only issue is it will idle around 1800 at cold start and when it warms up it will initially idle at about 1100 and 2 seconds later drop to 600 and stay there. It runs like clock work. I don't want to lower the idle cause if I do that it would more than likely cause the car to stall as it will possibly drop really low below 600. Any suggestions on what it could be. Also should the map and tps be the same on these throttle bodies or should I swap those out with the old ones. The car runs awesome though other then this issue. :cussing:
Every 2 seconds it fluctuates!
its doing its job, there no problem. tps is the same, if you swap it out, nothing will change and you will have to adjust it. If it aint broke dont fix it.
