It stayed parked for a while
@Soul Engineering's place until time was right to try and tackle it again.
Some time went past, and I pulled Grey car inside my shed to start preparations for installing the B series powertrain, and pulled out the D Series powertrain. So I had this nice ready-to-run D series trans just sitting there, if only I had a car to put it in....
So I made the decision to take Grey car's trans and install it to Green car, so that it would be a running/driving daily again. This would be temporary until I can build/figure out another street trans.
Made the trip over to
@Soul Engineering's shop, and proceeded to take the S20 popping-out-of-gear trans back out, and reinstall Grey car's trans. BUT, while we were at it and had everything apart, we decided the season was right to make some mods to Grey car's D series trans that were overdue:
- The black case S20 trans that was popping out of gear had a 4.25 final drive in it.
- Grey car's trans was supposed to be from a Y7, so it should have had a 4.05 final in it.
- The goal was simple, swap final drives between transmissions.
When we took Grey car trans apart, we counted the the final drive teeth to check for the 4.05. What did we find?
Grey car had a 3.722 final drive and gear set from the CX/HX civics!!!
That means I've been driving on track in Grey car with a fuel sipper trans setup hahaha. Needless to say, even with the 1-5 CX/HX gearing, changing the final drive from 3.722 to 4.25 would result in some nice acceleration gains.
Here's the before and after in Zealworks calc, same gearing, only thing that changed is the final drive:
When I take this trans back out as soon as I build another street trans for Green car, I have an .848 5th gear to install that will be better on the racetrack with the D powertrain in Grey car.
I was able to get close to hitting rev limiter before the braking zone on the back straight at VIR in Grey car with the 3.722 FD and the 0.909 4th, which means keeping the 4.25 FD and installing the .848 5th will allow me to tach the car out before that braking zone:
But enough about the racing side of things in Grey car lol, this is about Green car being a street car, and all the shenanigans that go on with street cars lol.
So we got the 4.25 final drive installed in Grey car trans, it looked great. Buttoned it up and installed it to Green car and went for first start up.
First crank, you could hear a ticking noise that was less pronounced with clutch pressed in, and ungodly loud with clutch released. We went through the motions:
- Checked for starter/starter bolt interference.
- Flywheel inspection cover interference
- Release bearing and fork oddities
- Etc.
After testing each, nothing really stood out that said it was any of these things. The noise was still there, and followed when you released the clutch pedal. It did it even with your foot on the brake, so the internals of the trans were NOT rotating. All of this meant the issue was isolated to the flywheel/clutch/bellhousing area.
Don't ask us how this happens, but I've NEVER seen this before in all my years as a tech. Keep in mind, this issue was NOT present with Green car's original trans, the swapped in S20 black case trans, but for some reason only showed its face on Grey car's trans. We found and realized two things:
- Trans cases I guess can have different casting and machining differences, causing clearances between things to change. This makes sense, so long as certain thresholds were met.
- There are supposed to be 6 flywheel/pressure plate bolts, how many did we find? ONLY 3 INSTALLED! You know what was installed in 3 out of the 6 flywheel holes in place of pressure plate bolts?? These f*****s:
REALLY? WHY?? WHO??? The noise was literally from the pressure plate flexing and touching the inside of the trans case. We pulled the starter motor out, and rotated the engine by hand to get access to the holes with the missing bolts, to install new ones. We were able to remove the christmas tree trim clips from the inspection cover side. Installed 3 additional bolts, threw the starter back in, and the noise was GONE!
Took it for a test drive afterwards, man was she a ripper, especially with the cold air moving into the winter months!
Brought it back to
@Soul Engineering's shop, and started packing/cleaning things up. We checked under the car to look for any leaks, and noticed there was a wet trace against the lower control arm on the passenger's side. We figured it was just extra fluid, and I also didn't have any thread sealer around the countershaft end plug cover, so we figured it was a combination of these things possibly, but in either case I was ready to tow the car home on the car trailer, I would just throw it up on ramps, clean off the fluid, pull the plug back off and use some proper thread sealant, and be good to go.
But OH NO.... things can't possibly be that simple. That close to a daily driver again? Nonsense!
