1 - 19 of 19 Posts
Acura TL-P
A sneak peak of the 3D model of our new investment cast Stainless Steel turbo manifold for the B series. (D series will soon follow). We will be testing these soon and will be followed by a production run and release. Stay tuned to GO-AUTOWORKS
Honda Civic
This is so sweet! A few of my stops on my route do casting and it's a very very interesting process. I always find myself stopping at different stations to see what the workers are doing.
You guys never cease to amaze me!
B-series Destroyer
4g 4d civic
So.....too early to get pricing? For the B-series.
Acura TL-P
Looking good!
Thanks guys :TU:
Ahh... Can there be a top mount version coming soon..?
It is a thought up in the air right now. Once we finish the testing on this one and lay out the D then that may be next. Its a long and thorough process, but a 3rd may be on the way.
It will come in priced slightly less than our SS log manifold. This will replace our welded SS manifold and will only be available through us directly and our distributor network. Backed by a LIFETIME top to bottom warranty.
B-series Destroyer
4g 4d civic
So roughly $300? Hmmmmmm.
Wow really interested just picked up ur v2 cast mani to replace a cracked log mani def would like to see the results
Sent from my iPhone using AG Free
Acura TL-P
W'ell be going over fitment and clearance before finalyzing and approving the design over the next few days.
Two men shy of a group
99 civic sedan ex
thats pretty slick looking but what about the dipstick tube i see in the last picture, it looks like it has nowhere to go
OEM dipstick definetely doesnt look like it would work
Wastegate on the top? Is that a drilled hole for the wastegate I see just beyond the top cutout
If you made a top mount for both B&D, that clocked the turbo parallel with the engine, and had the same wastegate placement (underneath) as the SPA manifold. You would sell those things like hot cakes
A cast and a steel tubular of that style would probably make someone rich
SPA only messed there manifold up because it rotates the turbo completely the wrong way
Acura TL-P
Discussion Starter #19
The OEM dipstick will clear, that isnt an issue; despite what you may be gathering from the picture angles. The clearance is no smaller than our standard cast manifold.
The investment casting is in 304SS
1 - 19 of 19 Posts
