1 - 20 of 31 Posts
I put a new y8 into my 97 civic ex coupe and now it won't turn over. I got spark and fuel so I have no idea what it could be. Any ideas?
check grounds. what ecu? check timing.
Grounds seem fine, ECU was replaced and worked right before I took out this motor, how do I check the timing?
fuel
spark
compression
you have to have all 3.
how do you know it has fuel and spark properly when it does not turn over?
Figure out why the starter is not spinning first
Reactions: slo_eg8
Discussion Starter · #7 ·
Fuel pump is priming, there's gas on spark plugs, I pulled off the banjo bolt on rail while it had a little fuel pressure and sure enough gas came out.
Spark, I has a buddy stick a screw driver into the spark plug as I turned the key and we got a blew arc on all 4
Discussion Starter · #8 ·
I lost the original nut that goes to the engine harness positive wire to the tranny. Maybe that could be the problem? Idk
Sloppy Jalopy
the only positive on the transmission is the wire for the starter ...
Discussion Starter · #10 ·
Sloppy Jalopy
so,do you have a nut to hold that wire on the starter post?
try a cap that isn't cracked ,dry off your plugs ,make sure all the harness plugs are going to the right sensors
and try again ..
Put a nut on the starter stud to hold the power wire.
Change out the cracked cap for a new one.
You will need to put the motor at top dead center on conpression stroke and make sure cam and dizzy line up
Discussion Starter · #14 ·
Will do
When I installed dizzy the motor wasn't tdc. How do I ensure cam and dizzy are aligned?
distributor should only fit one way via key slot. But dumbass's have in the past jammed it on there and wondered why the engine was farting out the intake and rattling the pistons
be careful, doublecheck your work, and if even slightly unsure. Look it up.
Gain some experience. But do not rush anything!
Discussion Starter · #17 ·
Dizzy slid in real nice.
Replaced the cracked cap and still no start.
I still do not see a response to my original question
DOES
THE
ENGINE
SPIN
OVER
WITH
STARTER
Reactions: slo_eg8
1 - 20 of 31 Posts
