1 - 7 of 7 Posts
It's called Rev and the title pretty much explains it. Unfortunately it uses only OBD II right now. Still, one step closer to that mad dream of chrome on the iPhone. :TU:
"Rev Features
Built-in Metrics (No special hardware required)
Lateral and Forward Acceleration: Graph your cornering, braking and acceleration G-forces. (Available in Rev Lite)
GPS Track: Visual track displays your location and acceleration data - see how you are braking and accelerating around corners. (Available in Rev Lite)
OBD Metrics (Requires OBD-II/WLAN interface hardware)
Vehicle Speed
RPM
Fuel Consumption
Engine Coolant Temp
Fuel Pressure
Calculated Engine Load
Throttle Position
Intake Manifold Pressure
Air Intake Temp
Timing Advance
Mass Air Flow
Fuel Level
Barometric Pressure
EVAP System Vapor Pressure
Fuel Trim
Visual Representations
Gauge: Displays a moving needle and LED display to show current reading
Graph: Displays current value over time
Engine Code Retrieve and Reset
Want to know why your Check Engine light is on? Rev will tell you why!
Engine code checking
Listing of all engine codes thrown by the vehicle
One-button reset of your codes and Check Engine light
Auto-centric User Experience
Rev has been designed to be easy to use in car-mounted iPhone/iPod Touch installations.
While we OFFICIALLY DO NOT RECOMMEND USING Rev OR OTHER IPHONE/IPOD TOUCH APPLICATIONS WHILE DRIVING, we do think it would be a mind-bendingly awesome experience were anyone to actually try it.
Quick taps for bumpy rides - double tap gauge to zoom in/out, swipe to graph view
Car-mount-friendly orientations - landscape or portrait
Dark background color scheme - easy on the eyes, day and night
Wireless Freedom
Simply connect to the OBD-II/WLAN device by approaching your car. While connected, your iPhone can still access the Internet via EDGE or 3G."
<object width="425" height="344"><param name="movie" value="http://www.youtube.com/v/iRfLS6jkBMY&hl=en&fs=1"></param><param name="allowFullScreen" value="true"></param><embed src="http://www.youtube.com/v/iRfLS6jkBMY&hl=en&fs=1" type="application/x-shockwave-flash" allowfullscreen="true" width="425" height="344"></embed></object>
<object width="425" height="344"><param name="movie" value="http://www.youtube.com/v/o91DX4ODgbU&hl=en&fs=1"></param><param name="allowFullScreen" value="true"></param><embed src="http://www.youtube.com/v/o91DX4ODgbU&hl=en&fs=1" type="application/x-shockwave-flash" allowfullscreen="true" width="425" height="344"></embed></object>
Asshole
The iPhone continues to amaze me everyday. My friend has one and I cant wait to get one as soon as someone unlocks a 3G.
10 second daily driver :)
i just jailbroke my iphone a few weeks ago and im very pleased with what i can do on it now, so many applications for jailbroke phones that apple will never release :( plus i changed the entire theme and look so its one of a kind now.
1 - 7 of 7 Posts
