1 - 3 of 3 Posts
9
HEY I JUST GOT A 90 CIVIC HB WITH A D15B6 IN IT WHAT IS THE HP AND ENGINE SPECS......THEY SAID IT HAD A ROCKER MOTOR WHAT IS THAT???? should i do a swap if so what and how much and how diffucult???? thanks myk
Youl have to ask your friends what a "rocker motor" is. The first thing you would want to swap is the MultiPointFUelInjection system with 4 fuel injecters if you only have the DualPointFUelInjecstion system.
DPFI
MPFI
You would need the 88-91 civic si distributor for the 1.6l d16a6 engine, the 88-91 civic/crx 1.6l pm6 ecu, and the 88-91 mpfi intake manifold.
If you have the mpfi the d16a6 would bolt rite in where the d15 is.
9
will a d15b2 distrubtor fit the d15b6 motor?...
1 - 3 of 3 Posts
