1 - 20 of 24 Posts
so i started my first single cam build and had a question or 10.
i bought a built z6 head (ported polished,omni valves,compcam springs ret.) checked it all out and saw that it had a huge cam. did some research and found out its a stage 3 crower cam!!! im currently running a stock z6 head now on a d15b block on 7 psi. so my questions are..
is it ok to boost on a stage 3 crower cam?nevermind this q. did a lil serearch
where do i set the valve adjustment at?(.004 intake .006 exhaust?)
what timing belt do i use?(im thinking a z6)
and last haha... has anyone ran boosted on a crower 3 stage cam?
I can't read...
whatever the crower website tells you
z6 i believe
never! no one has ever done it!lol
i'm sure its been done. no one that i know of has...
yeah, im sure. im just going to just go ahead and use that bad boy...im kinda sketchy about it but owell.
i have the stage 3 but have only ran it n/a in couple days i should be able to say yes. what questions do you have about it????
WHAT DO YOU SET YOUR VALVES adjustment AT? HOW BAD IS THE IDLE?
THanks in advance homie
I believe you set the valves to OEM spec. That's how I did it on the both Zex cam's we've had, 300 and 500 series.
ive heard otherwise.you had no problems?
lol then do what you want to do, set them to whatever you want to set them too..
i hate when people ask questions, and then someone helps, and then they comment and say, well ive heard otherwise... well why do you even ask a question then..???
obviously he wouldnt be telling you something thats not going work...
relax FOO, dont cry just relax.:booty:
the cam might work it might not.. it wont blow up it just mgiht make good power and it might make crappy power.. depends on the lift and duration
sometimes big n/a cams have to much overlap which sucks for turbo
this is true. i was really hoping someone has allready tried it. will, ill be the first on here to try it then. thank you kind sir.
1 - 20 of 24 Posts
