I just replace the head gasket on my d16y8 and installed some new ARP studs. Got it all put back together and tried to start it. Engine turns over but wont start. Im guessing its the timing belt causing the problem because i was stupid enough to forget to set the cam and crack and tdc before taking everything apart and im sure its at least a couple teeth off now.
so my question is, can i remove the belt from the cam, rotate the crank to tdc, then rotate the cam to tdc, then reattach the belt without having to take everything else apart? according to my manual that should work, ive just heard so many horror stories about people smashing their valves doing similar things.
also i was planning on putting a skrew driver into the number one cylinder then rotating it untill its at its highest point, is this an accurate way to find tdc?
