1 - 7 of 7 Posts
civic coupe
ok i feel RETARDED but
i just swapped my aem fuel rail and fpr (Bseries)
i have earls stainless lines too...
well now the car wont start?? i made sure everything was on nice and snug, plugged injectors back in and it just cranks and cranks and cranks....
its stated 2 times and then got to 1500 rpm then dies :3dtard:
96 civic coupe d16y7
well shipp the fuel rail to me and ill take a look,but if its broken i get to keep,but ill just say that anyways gl
tristan, i get off at 4, lmk
ill come and bring two diff regulators,
also, i saw you had white teflon on the fitting, near the filter, (maybe a piece got sucked up in the line, blocking it?
and are you 100% sure no leaks, because if its leaking, my thoughts are fuel isnt going in the engine enough to run.
but lmk
civic coupe
i took the teflon off the second time i took the lines off to check for leaks....
ill be in ky till about 5 or so but ill give you a cal, it may be the fpr
1 - 7 of 7 Posts
