1 - 7 of 7 Posts
Ok so I get done with my turbo kit tonight and I go to start it and I realize that my fuel pump (walbro 255) doesn't kick on. So I jiggle the wires and it comes on for a sec after fking with it for a couple of minutes. So i scrub the connectors and it doesnt help so i put some new female spade connectors on it that are shielded to the top so they don't ground out. This doesn't help. I tried hooking up my stock pump and that didn't so anything. I put a test light to the wires and it doesn't turn on. So then I grounded the ground wire to the stock pump straight to the body. This doesn't help. So after doing some research do you guys think its the pgm-fi relay? Any other thoughts? Please HELP!!! THANKS
looking at the hayes manual it goes straight to the relay no fuse and there isn't a fuse named fuel pump
R2.....Zap Balls
mikeD16Z6 said:
main relay
x2, the harness on mine got loose just a little and did the same thing until I snugged it back on
1 - 7 of 7 Posts
