1 - 4 of 4 Posts
U
Hi,
Just purchased my first Civic for a commuter.
93-lx-4dr-auto-172K-slow.
It has factory driving lights, one of them is burned out, and I cant figure out how to replace the bulb. Owners manual does not mention, nor does the Haynes manual.
I took off outer cover, and I see the 3 large screws, but they wont budge. What is the right way to change the bulb, and what kind of bulb is it?
*Also, I have no idea when the timing belt was last changed, and there is no sticker under hood. Any easy way to check the condition, or should I just replace the belt & water pump now?
Thanks
I
best bet is to replace em now before they go out - cuz u'll eventually hafta replace em anyway, better now that you have time than when ur in a rush or in an emergency
can't help ya much with the bulbs tho, don't know myself actually
the hard-parker
check out the DIY forum and see if there were any posts in there about the headlight.
M
change the timing belt no matter what. you wont get a second chance if it snaps!!!
1 - 4 of 4 Posts
