1 - 20 of 27 Posts
yellow bar for me
viper blue 92 eg
already posted this once, but the site deleted it???
anyways, went to the track friday and made a few passes. after getting my timing somewhat right(10 degrees btdc) and having a fresh bottle. i managed this time
rea---.804
60---2.230
330---6.030
594---8.523
1/8---9.093
1/8---78.94
that was the first and best run of the night. i dont have a nitrous pressure gauge or a bottle warmer so i was loosing pressure im sure. that and my stock clutch doesnt like 200ft lbs of tq in 3rd gear after one pass.
next pass
---.607
2.268
6.198
8.692
9.251
80.50
mph went up, time went down. damn shitty traction.
yellow bar for me
viper blue 92 eg
my conversion chart says a 9.0 is a 14.07 and a 9.10 is a 14.22. these are just approx. numbers
yellow bar for me
viper blue 92 eg
that is my trap in the 1/8 mile. i would have trapped in the 90s in the 1/4
yellow bar for me
viper blue 92 eg
ya i hope to be in low 14s. once i get my walbro in i am going to up it to a 100 shot and do a nitrous tune and an all motor tune using a two timer and crome pro. hope to be in 13s then. i think i am going to make a trip to steele and see what it does in the 1/4
yellow bar for me
viper blue 92 eg
b18b1 with i/h/e test pipe, aem fpr, nitrous works 75 shot. ngk stock heat plugs.
Z6, 55 shot, 13.97 first pass.
OK, I always used slicks, street tires are useless when bottle fed.......
only time I made a 14 second pass on the bottle, was the last pass the motor ever made, drove it home and yanked it out, TOAST!
yellow bar for me
viper blue 92 eg
ya i have a set of slicks now. i have to put my new axles in cuz both of mine are poping. then i have to learn to preload. is anyone running stock axles on 300 hp cars? or should i invest in high hp axles. 300 is my goal for a pretty good while
yellow bar for me
viper blue 92 eg
if my z6 would have stayed together it would be faster. i had just about everything i wanted for that motor. fuckin rod bearings.
Crx
traping 80 in the 1/8th will get you in the 8.90s easily with a 2.13 or better 60ft, change your launch a little, 2.0s are easily acheivable in street tired integras on nitrous im sure you can fiqure it out too
yellow bar for me
viper blue 92 eg
Discussion Starter #20
ya ill be boosted in the next couple of weeks. if i can keep traction im hoping for mid 8s on stock internals
1 - 20 of 27 Posts
