I'm rewiring my interior..
engine bay SI harness is installed
Interior wise.. DX harness is stripped out..
SI cabin harness is pretty much all in
Except a couple plugs are not matching up and there some extra..
I'm freaking out..
For the portion of the harness that goes to the rear of the car, there are differences in the plugs I'm guessing..
Any suggestions on what I should do?
Thanks
Brian
OMG TOTALLY COOL TITLE!!!!
88 y49 crx
sounds like he didnt wanna do the dpfi to mpfi swap so he went the longer route of swapping both engine and chassis harness to the si one
I did the MPFI conversion, it worked well with my a6
I got the cabin harness with a trade.. So I decided to do the swap over the break.. ouch
Problem is its a 88 89 harness and i have a 91
I know that now.. but i still need the wiring diagram = [
:scared:
Alright I been following wires.. and the anxiety comes into play heh..
This wire is on the SI harness I installed last night (No where to plug it into)
This wire is on the old DX harness, and I need it to connect the main harness to the rear harness (Not on the car right now)
This harness plug is on the Rear harness of the DX.. And It plugs into the previous plug shown (On the car)
This plug is on the SI harness (On the car) No where to plug into
OK question can I directly splice the wires into the plug on the SI harness (near the steering wheel)
With the wires from the SI harness (near the kick panel)
To create the plug on the DX harness (Not on the car)
And plug it into the Rear harness plug
Thank you for your help, it's complicated i know so i appreciate all help
Hope my words are clear enough
