So I purchased a ek from a bank repo, problem is motor is in the trunk has a y5 head and a y8 block I am going to break it down and replace gaskets etc .problem is I have never seen this match up , Is it gonna run correctly with that set up ? Or should I just look for a different set up?
try a search? and why did you make 2 of the same threads?
Seems my phone jacked uploading I didn't think it loaded so I reloaded and it was same thread , Also I tried a search and didn't see anything relating to my current set up in this car .
Discussion Starter · #5 ·
Seems everyone stays away from using the y5 head,the one I have is a y8 block y5 head from the links you have sent me they are changing the heads on stock y5 to y8/z6, from what I have read and back tracking others post I can use the y5 head y8 block y5 timing belt and the y5 ecu, and have a functional set up , guess I should have originally asked if anyone has used this set up before
