In the process of building the engine for my del Sol I've opted out of using the FITV by using a B16A TB. I feel it looks cleaner under the engine bay, and it's one less mechanical thing to deal with. But earlier today I was able to fix a friends car that had an idle issue. A b7 with a b16a TB on it thus eliminating the FITV like I've done. The way we were able to fix the issue was by installing a factory b7 TB with FITV and the idle issue went away. This now has me thinking, do I need an FITV on my engine for it to run properly?
I know the FITV is the Fast Idle Temperature Valve, it opens up adjusting the idle in colder temperatures and once the engine is up to operating temperature the valve closes no longer affecting the idle of the engine.
I've read that if you live in a warmer region that deleting the FITV will not be as big of an issue as in a colder region. I never plan on driving this car in colder weather, it will stay locked up in the garage during bad weather and winter time.
But another thing that has me thinking is with OBD2 engine such as the y7 and y8 they no longer have the FITV from factory. So in colder weather how do they adjust the idle without one? Does the IACV control this some how in a way that the IACV on a OBD0/OBD1 car didn't? Is there something extra in the programming of the OBD2 ECU that controls this? How are newer cars without the FITV getting by in the winter time?
So to sum all of this up, how will my engine run without an FITV?
