1 - 7 of 7 Posts
I recently picked up a 1990 civic hatch, Standard model with the 4spd manual and d15b2 in it. car has 191,000 miles on it. The issue I am having is an odd noise. When I am at low throttle I hear what sounds almost like a grinding noise of metal grinding, but if I tap the gas it will go away briefly. It is fairly consistent only at low speed and low throttle.
I have heard maybe a trans/motor mount is bad? Could that be the cause?
Any help is greatly appreciated
Thanks
stock sedan
check the oil for shavings, could be a main bearing
stock sedan
well i just thought that it would kinda make sense to only hear it at low throttle b/c of hardly no engine noise G/L
yeah it always a good idea to check. need to change the oil. lol but havent done it yet. car is on stands. installing a header back exhaust on it.
1 - 7 of 7 Posts
