Cliff notes at bottom for people that don't like to read
I've got a 93' civic LX 5speed, with 252,xxx miles on it. I have no records of the car. When I bought it I changed the spark plugs, cap, rotor, valve cover gasket, right front tie rod ends, front coil springs, installed a few poly bushings in the front lower control arms, and brake master cylinder.
The parts I've got, but haven't installed yet are; a d16z6 intake plenum, throttle body gaskets, intake manifold gaskets, PCV valve, OEM fuel filter, and short ram intake. I also need to replace the oil pan, do to it being dented to hell from the previous owner. Then I need to figure out whats leaking from the back of the engine below the intake plenum.
I have access to my own lift, tools, and discount from dealerships/autoparts stores in the area.
The car runs and drives great (minus torn RTAB's). I'm pretty new to actually working on Hondas, so I'm just looking for a few helpful tips from fellow d-sereis owners on what I should do to keep the ol' d15b7 running strong.
Cliffs,
1) What kind of things should I be replacing/looking for while I have the intake plenum and oil pan off?
2) What are some general maintenance items/typical problems for a high milage (250k+) D-series?
3) Where are some good places to purchase OEM Honda parts online?
Thanks in advance everyone!
-Ethan
PS. Tried searching through the first 10 pages that "maintenance" came up with.
Cliffs,
-Ethan
