1 - 9 of 9 Posts
Hi
I need some dyno's of d16 with <GT2860R/S GT2871 and so on.
Turbod16 currently down so can't use them they got. Need some proof to some guys i know that say a GT2860 first will make 15 psi at +5000 rpms
And that everything bigger than that will lag like hell.
http://www.turbobygarrett.com/turbobygarrett/catelog/Turbochargers/GT28/GT2860R_707160_5.htm
this one should correct but it should be laggy you should post pics of your turbo but i have a good feeling it should be laggy at 15psi but i know for a fact that shit wont make 15 psi at 2500 maybe at 4 and up im not sure. my friend t3/t4 57 trim 63 a.r make 18 psi by 4000 rpm so i dont know lol. but seeing that its a smaller turbo and its bb and is a t28 with a t3 compressor wheel i might be wrong about that but if im correct then it should spool quik. but remember bigger downpipe is a good thing or open downpipe helps spool
Thnx man, but not what i needed, need dyno sheets on already installed above mentioned turbos.
i tried google and i couldnt find any set-up of people that have done it i mean the recommend it for 300hp along with the gt28rs and the 71r but nothing on the gt2860 that i can find
Nah i also tried google. But im pretty sure that there are some examples on turbod16 in the highest hp topic or whats it called. But the site is down.
there should be i remember always being on that forum and there highest hp set-ups did have some gt series turbo's on there with dynos even a spool time sticky
I know you saved those on your computer. please upload:D
1 - 9 of 9 Posts
