1 - 4 of 4 Posts
i know this is D series but honda clutches are kinda universal i am fixing my girls sisters 94 accord its been sitting for two years i get in it and it has a little clutch pedal but very little i tried to open the bleeder valve on the unit by the trans to see if that was the problem and now there is no clutch pedal. before i did that if the car was off it would go into gear fine but when it was on would not go into gear but you could put it into a gear then start it then drive the car in that gear. need a second opinion on what this could be thanks.
It's that time again
MAIN ONE IZ A CIVCSI
is there fluid in the reservoir? this would be a 2 person job but you would need to bleed the system
1. make sure the reservoir is full(you could just tip over a brake fluid bottle)
2.you would pump the clutch pedal even by hand if needed about 5 times
3. right after (the other person can) release the bleeder screw an tighten back up right away after pressure is released
4. repeat as need.
noob
95 Civic Coupe
pump up the pedal and open the bleeder valve....repeat over and over intil you get a flow of fluid only. Add fluid to the reservoir as needed.
1 - 4 of 4 Posts
