A guy i know has a d16z6 that hes built for sale i need to know what you guys think of the build and wether or not i should buy it. Thanks
Hes selling for $1300......
Head
D16z6 head, rebuild by Cylinder Head Service in Spokane, WA
Stock port
New OEM valve seals
New OEM retainers
New OEM valve keepers
New OEM spark plug wires
NGK bkr7e spark plugs
Supertech valves
Supertech valve springs
Skunk2 IM
LS 60mm throttle body
Zex 59300 cam
OEM z6 cam gear
Block
D16z6 block, rebuild by myself
YCP 75mm Vitara pistons
Hastings rings
Eagle rods w/ big bolts
ACL main bearings
ACL rod bearings
ARP head studs
New OEM head gasket
New OEM main bolts
New OEM oil pump
New OEM water pump
New OEM oil pick up
New OEM oil pan gasket
New OEM timing belt
New OEM timing belt tensioner
Head
Stock port
New OEM valve seals
New OEM retainers
Supertech valves
Skunk2 IM
Zex 59300 cam
OEM z6 cam gear
Block
Hastings rings
ACL main bearings
ACL rod bearings
ARP head studs
New OEM head gasket
New OEM main bolts
New OEM oil pump
New OEM water pump
New OEM oil pick up
New OEM timing belt
