1 - 3 of 3 Posts
S
ok so i change out ISB and every other bearing in the tranny, all gears work fine xcept for reverse, with out the reverse shift arm in it moves into reverse just fine
the second i put in the reverse shift arm in it locks me out of reverse,
everything look fine in the tranny i just cant figure it out yet and its killing me
also can some one tell me if everything looks ok i followed the honda tech manual to the T. and i also used the how to that i found online.
everything is in except the reverse gear and pin.
i need all the help i can get so please help me out
S
enven when i assemble everything i still get no reverse gear, im moving the shifter with a large pin so that i can shift through the gears, everything moves freely as long as i dont install the reverse shift arm, im just locked outof reverse,
is there anything special i need to know when installing the reverse shift arm?
1 - 3 of 3 Posts
