1 - 6 of 6 Posts
Hi all, I recently purchased a 99 Coupe Ex and have plans to build it and then turbo it. From the little research I've done my plan is to get someone to bore it, put in forged pistons and rods, and a skunk 2 intake manifold. What horsepower should I get out of this engine with a 50 trim turbo? Do any of you foresee any issues with my plan and what other parts should I expect myself to need to adapt or replace as I have never turbocharged a Honda engine before. For example I believe I read somewhere that on specifically the Y8's the oil pump is bad?
spend more time reading.
Reactions: robgoof
Where should I be looking? I mostly find old forum posts from 2008 or older that don't mention any modern products or companies. Are you implying that I do not have enough knowledge on this build to make a plan or do you see actual issues within what I have put out.
so what if theres no "modern companies" mentioned? what do they have with what people have already built? do your own leg work. see what people have done, what works, what doesn't, and whats prone to fail.
Sloppy Jalopy
you seem to be over simplifying ,have you done much tinkering in the past?
Do some more reading as slow suggested.
do specific searches for each item or sector ..
to start you on your journey... long twisty web
there should be a rule ,you can't post till you have memorized theoldone ...
Regarding the oil pump:
Here are the relative flow rates of different generation Civics. Perhaps the oil pump reputation is from 33.4 lpm being the lowest, but is it enough anyways?
01-05 36.4 lpm, 38.5 US qt/min, 32.0 imp qt/min @ 6000 rpm
96-00 33.4 lpm, 35.3 US qt/min, 38.6 Imp qt/min @ 6800 rpm
92-95 45 lpm, 11.89 US gal/min, 9.90 Imp gal/min @ 6000 rpm
1 - 6 of 6 Posts
