I need to know if the bearings from a d16a1 are the same as a d16z6 if you buy them new. I am rebuilding my z6 block. I am putting the p29/pm7 pistons in my z6 for higher compression I have been reading alot about this over the last month and I just need to know about the bearings thanks. I am going to be using p29/pm7 pistons my stock z6 rods and im trying to use d16a1 rod bearings, main bearings, and thrust washers
Boost Gets You Laid
Using a z6 block crank and rods, use the bearings for the z6. Only thing that would be differant from the z6 would be get piston rings that match your pistons.
this is what I planned on doing I just bought all the enternals for a d16a1- pins, p29pistons, main bearings, rod bearings, thrust washers, piston rings and what im using from my z6 block is the rods and crank just trying to run higher compression
