1 - 2 of 2 Posts
1988 crx
ok. my bud came down yesterday and he connected the clutch
already. and than the throttle body.. a few other things.. but these
are the things i still need.. by the looks of it i need a new shifter because my gears go really far away from each other! ok i need
-to get another fuel pressure regulator. so it could turn to the right
and connect to the return line.
- i need a hose to connect to the back of the manifold
- i need the rubers for the injectors so it wont spill out gas
- and i need to find where the hose goes to what connection..
so i need help on where the hoes goes.. we cant seem to find the connection to the motor.. and another thing?? do i need that thing that goes mounted on the throttle body??
CRX, Wrangler
I think you're missing some things on your intake manifold (On the throttle body, specifically).
I've never owned a DOHC ZC, but my IM looks like this on my A6:
Note the hose that you still have disconnected is connected to a vacuum diaphragm on mine which helps control the idle.
Let me look more, I may edit this post and provide more answers.
-Des!
EDIT: Your clutch cable is routed wrong. It needs to go between the valve cover, and the intake plenum. It gets hooked to the black bracket that's partially obstructed from view from the FPR in my picture.
1 - 2 of 2 Posts
