1 - 12 of 12 Posts
97 honda coupe
will i be able to use these springs with my cam?
1988 CRX
I've read that Z6 and Y8 springs are the same, so you should be able to use them fine in your build.
the z6 and y8 springs are the same
part numbers (with disregard to head casting (p2e etc) in the part #) are identical in the honda catalog here @ work.
one exception in my mind:
i believe the intake springs are documented to be quite a bit stronger than the exhaust side. some people have run two sets of y8 intakes and have tested to 8000 or slightly above on it. i think danz did this once if im not mistaken.
i'd just spend the extra 100 bucks on supertechs and call it a day but good luck sir!
del Sol si '94
Ive got Supertech Z6 springs on my Y8 head, do it! lol Gl
ok thanks all im just getting my parts all lined up so as soon as i get my tax return i can order them right away will keep everyone posted as i get the parts in.
1988 CRX
That's what I did. Cheap insurance, really. Peace of mind. :yes:
1 - 12 of 12 Posts
