1 - 9 of 9 Posts
Ok I really use someone's help Please .
I just did a swap on my 97 civic si , y8 tranny and bottom end and a z6 top.
the problem I'm having is that car has a rough idle , almost like it's miss firing.
We also took it for a drive once it heats up you drive a around for a bit and when u come to a complete stop the car stalls? And last but not least my vtec seems not to be working!
Now if you guys know, a swap like this is weird ...............can't use a 97 dizzy won't fit, can't use a 94 dizzy won't start. So what I did is I used a 94 dizzy casing with 97 internals.
Can these problems be the dizzy, or the aem adjustable cam I have on the motor?
Need cAr to run ASAP please help!
formerly allnaturalrex
1989 honda crx si
did you check timing?
1989 honda crx si
no need to make 2 posts
If I advance it forward toward the front of the car it runs worse if I lean it back towards firewal not so bad
1 - 9 of 9 Posts
