1 - 2 of 2 Posts
hello guys.
i need some help with hondata s300 tuning,
iv tuned alot of cars with crome, and i want to make sure i got the base right,
this is the order of things i do:
open a new basemap, lets say a p28,
set to open loop (disable closed loop)
choose a map sensor
disable everything in misc/options :knock sensor, eld, inj error, baro, alt c, ignition output.
in fuel injectors:
setting current injector size to what ever, lets say 1000cc (leave stock injector size at 240cc)
choosing injector offsets
uploading map to ecu, + dataloging
setting my tps range closed + open
starting the car, and while waiting it to warm up i play with the overall fuel trim to get good AFRS for idle, some cars want -20 some +20 some like 0, i am NOT using the "calc / calculation" should i ?
then i apply electrical load to adjust battery offsets,
set fuel pressure
lock timing/ set dizzy.
select gear ratios,
start tuning for cruise, then boost,
thanks
hondata says: The general approach tuning mixture is to adjust the injector multiplier (overall fuel trim) until the mixture is as close as possible to ideal while the engine is under full load. Normally this will result in the part load settings giving close to ideal mixture as well.
wtf??
97 honda coupe
hello guys.
choose a map sensor
in fuel injectors:
set fuel pressure
select gear ratios,
thanks
wtf??
If you select a fuel map that somewhat resembles the map that you want its a matter of lining up the slope of the fuel curve with that of what the engine actually needs.
your list seems pretty complete depending on how built the motor is, you might have to mess with the iacv settings to get it to idle right or change the hysteresis for the adaptive idle.
Although i dislike the creators of the program and specifically how they came about. hondata does work very well and is very sleek. you shouldnt have any issues tuning the car.
1 - 2 of 2 Posts
