1 - 3 of 3 Posts
nothing
does anyone know how to use a map from the bin files at xenocron and switch the map sensor and the fuel injectors using crome???
going to be working with it a little bit tonight along with another member from dso in a few hours could anyone share this with me quickly?
95 hatch
Pretty sure you can download the bin and just open it right up in crome. For the injectors you can click "f" and the fuel multiplier should come up and you just put in the new injector size. And for the map, i'm not 100% sure but i think you can change the mbar setting in the editor settings under general.
Hope it helps a little.
Edit: Oh, and if your datalogging you should go to plugins - enhancements - datalogging +RTP.
nothing
no were not datalogging were just using a map that was already used and changing a few of the settings around for my application.... thank you i will give this a try here tonight.... anyone else feel free to give any advice!
1 - 3 of 3 Posts
