1 - 9 of 9 Posts
i found a set of vitara pistons with all rings with eagle connecting rods..its off ebay...heres the discription
NIPPON RACING VITARA G16K TURBO PISTONS
EAGLE FORGED 5394 H-BEAM CONNECTING RODS WITH ARP 2000 BOLTS
NPR GAS NITRITE N-51 TREATED PERFORMANCE RINGS.
9310 CASE HARDENED WRIST PINS WITH UPGRADED CLIPS
KING PERFORMANCE ROD BEARINGS
THE COMPRESSION RATIO IS APPROX 8.5:1
its for sale for 525.95
would you buy this for your turbo rebuild??
looking for quality...and just want to know if nippon vitara pistons are any good
would reccomend vitaras and fj custom length i beams. rods are rated to 500hp.
www.fjdistributors.com (also a site sponsor)
I've read that the NPR Vitaras are not of the same quality as the YCP.
Do a search on NPR vs YCP.
None of the big HP builds use NPR.
The compression ratio is dependent on what motor combo you will be using. It can range from 6.9-7.8 This is due to the vitara piston dome being -15cc and the wrist pin location being higher on the piston. Your head combo will also affect compression ratio plus any machining work will also.
Play with this: Honda D-Series Compression Calculator by ZealAutowerks
Only way you will see 8.x compression is with FJT Custom I-beam Rods.
King Bearings are a failure too.
Go with FJT: FJ Distributors
racist-bigot-sexist-homophob
Yep, YCP vitaras > Nippon. Something about the material or casting process is different IIRC.
Knew it was something like that. Good info.
Reactions: christbone20
EK 96
YCP all the way. In a NPR or YCP battle but you can checck in the for sale thread there is always someone selling som good pistons cheap!!!and FJ connecting rods worth every penny.
1 - 9 of 9 Posts
